Com1 in use - need XP help
for some reason my BOE/BS2 quick communicating...·· It worked fine until I rebooted my PC the other day. Now when I try to connect with the BS Editor or Stamp Plot, I get a message indicating that the port is busy.· I have a 2nd Generation BOE (serial on Com1).· No new software has been installed, and no existing software has been changed.· I had the same problem once before, but it turned out to be my Palm's Hot-Sync Manager.· This isn't the case this time, as I have removed the Hot Sync software from the startup menu and have verified (using the Task Manager) that no Palm related applications or Processes are running.· I called tech support at Parallax and we took several voltage measurements - all which appeared to indicate that the stamp is functioning normally.· At their suggestion I reinstalled the editor, however I am still getting the same results.·· Can someone tell me how to troubleshoot XP (pro) to determine what is using my Com port?
Thanks A lot,
Patrick in Memphis
Thanks A lot,
Patrick in Memphis
·· Something is tying up the port...Are you sure you have all the parts of the Sync software disabled?· You could test this theory by temporarily uninstalling the Sync software itself.· Also, I would scan for viruses and ad-ware.
csavage@parallax.com
Sid Weaver
Do you have a Stamp Tester yet?
Sid
that fixed it. Now what would cause that to happen?
Thanks!!
Patrick
You could have an intermittently ·bad serial cable -· that does happen once in a while.· To eliminate that possibility for sure, I would buy a new serial cable and junk the one you are using now.
Sid
