Real time clock as a Virtual Periperal
Well, I have a bunch of Sx-18s and I am wondering if anyone has created a real-time clock VP for the SX.
I am thinking this would be independent of the main microcontroller.
From what I can see, having a clock on its own chip that can send and receive interrupts is better than having it included in your main microcontroller.· Without having a dedicated device, it seems that sooner or later, you have problems with interrupts throwing the clock off the correct time.
And,
Does anyone have a suggestion on a·prefered frequency for such an application?
G. Herzog in Taiwan
And,
G. Herzog in Taiwan
http://www.sxlist.com/techref/ubicom/lib/flow/clockvp/index.htm
other timers:
http://www.sxlist.com/techref/ubicom/lib/flow/timer_sx.htm
regards peter
Check out the PCF8583 chip. Pretty cool and cheap.
http://www.semiconductors.philips.com/acrobat_download/datasheets/PCF8583_5.pdf
John J. Couture
San Diego Miramar College
Real time clocks need very accurate xtals, as a very small error results in big changes.· Based on a 4mHz xtal that is good for driving a micro, can easily result in time gain/losses of 10 minutes per day.
The 32.768kHz watch xtal is the one to use, if you do not want to adjust your "clock" every day.· This introduces some limitations.
The more flexible approach is to use the Dallas time/date chip.· Drive this with the 32.768kHZ xtal and then use whatever speed you want on the SX.
Many years ago I saw very good information·in the app notes for the basic stamp.· Suggest you have a look.
Greetings from queensland.
bongo
Now I see the dilemma is not just about sharing the clock cycles, but sustaining a good tic at low power. Clocks must run 24/7 while the rest of the unit might be put into sleep mode.
The above Virtual Peripheral designated a 50mHz crytal [noparse][[/noparse]lots of milliamps drain]. Even the 32.768 [noparse][[/noparse]this is a bad assumption, see Bean's email·below]·would create a bit of a power drain, but at least the accuracy would increase quite a bit.
I· took a look at the PCF8583 and it is 50ma. The Dallas Chip seems to come in at 2ma !!! WOW and micro amps in standby with an optional backup battery.
Of course there could be some occasions where having an SX be the clock could be a big advantage - a customized, shared format for waking up the main micro-processor.
Also, if the SX is on an RS-485 network, one reliable clock could routinely reset all the others as a regular maintanance cycle.
G. Herzog in Taiwan
Post Edited (Kramer) : 9/21/2005 3:29:31 PM GMT
If you only need seconds or tenths of seconds it should be doable.
You can do alot in 3267 cycles...
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
G. Herzog in Taiwan
·1+1=10
The sx-key will work at 327_680 too. Which would be only 10 times faster.
P.S. Has anyone tried to make a clock that is syncronized by the 60Hz power mains ? From what I understand they have excellent long term stability.
Bean.
Red Green
·· Such a clock was in a recent issue of Nuts & Volts I believe...It used the 60hz from the AC line for it's clock base.· The part I didn't agree with was that they used the DS1302 or similar as a backup device for when poewr was lost, but maintained that the AC line was much more accurate than the DS chip.· I think it's funny the people that have the DS1302's and DS1307's that say they're inaccurate.· I have used several, and in a week they're never more a second off from the clock I set them by, so I don't see the problem with just using them.
csavage@parallax.com
I would assume that the DS1302 and DS1307 xtals are affected by temperature by possibly 50PPM or more. Where the 60Hz is monitored and adjusted to provide a very accurate timebase over the long term.
Bean.
Red Green
