Any way to shield compass from motors?
My application for the compass module involves placing the compass near some running·DC motors. It is above and behind the motors, but they definitely have an effect strong enough to make the compass readings·useless.· There are some·less desireable options·in which I can move the compass·far away, but·I was wondering if there is there any way to shield the compass from the magnetic effect of the motors but not from the magnetic effect of the earth?· Lead?· Enriched plutonium?
Is there anyway to re-position your compass so that it is away from the motors? (i.e. get the person in front of the TV to move)
Beau Schwabe
IC Layout Engineer
Mu metal?
I googled for it. Know of a source of metallic glass?
We dealt with this exact issue on the Penguin robots, but the problem was with the batteries (not the servos). Two solutions worked evenly well to solve our problem:
(a) A 0.050" steel shield between the batteries and compass solved it
(b) Moving it an inch away made it work even better.
(some mathematics:
http://forums.parallax.com/showthread.php?p=544957)
I just got a quote for mumetal from Mushield and it ain't cheap.· There is a $150 lot charge for 1-5 square feet for .14 inch thick sheets, or 1-20 feet of .002 inch foil.· Now, I wonder why they can't cut me a one foot square piece of foil·with some tin snips and send it out for, say $10?
I really don't want to move my compass far away from the motors for this application, but I may have to.· Or maybe a chunk of cheap steel will work.
And almost by definition, any motor IS a 'high-current' beast. Unless they have fixed magnets -- which has the same effect on your compass.
Depending on the size of the magnetic field generated by the motors, you can get large reductions in field strength with small movements of the compass. Try Ken's suggested solution using steel, mu-metal may be overkill.
Oh, here is a site that offers foil without a $150 minimum charge. $18.95 a linear foot:
http://www.berk.com/~lessemf/wiring.html
And look! They also have 1" wide metal glass tape for $2.50 a linear foot. Hmm. I only need about 2 feet!
