Touch Sensor QT113-D+Javelin+Hookup — Parallax Forums
WaldoDTDWaldoDTD Posts: 142
edited 2005-09-19 15:34 in Robotics
Hello,
I would like to know if the touch sensor QT113-D (link here) is compatible with the Javelin Microcontroller. If so how would one go about hooking up the javelin to the chip? Also, I would like to know how it would be hooked up to a sensor pad, I saw it could be hooked up to a piece of glass and was wondering how that would work. Thanks!-Hacker
    Hacker,
    ·· Yes, the QT113 is compatible with the Javelin.· All you're really looking for is a high or low on the I/O pin, unless you make use of the "heartbeat" function, which could also be done...But yes, fully compatible.
    csavage@parallax.com
