count
Could you please help me with the code for the following...
I want to count external pulses comming into a pin of the sx28 for a period of 2.5 seconds and send the result over serial conection to a pc.
This needs to be done with inerupts and I am not very good with progamming. I am using the sx basic compiler.
Jon Williams
The subroutine for counting needs to work in the backround and I dont how to do that. The serout is not a problem
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
The max count will be 150.
What is the mimimum on and off time of the pulses ?
What clock speed are you using for the SX chip ?
Bean.
Red Green
I am using the 50 MHz resonator that came with the kit but I can use the 4MHz if it is better.
I am not sure about the mimimum on and off time of the pulses but the pulse is generated from a reed swich which is connected to a rotating mechanism of an anemometer. One rev is one pulse. I dont know if this helps...
Be sure to change the pins and baud to whatever you are using.
Bean.
Red Green
I will give it a try and hopefully it will be ok.
Thanks again for your time
I fear that I have led you astray. I completely forgot about the RTCC input on the SX chip.
You can simply connect the signal to the RTCC pin and use this code with no interrupts...
Here is a much improved program...
Bean.
Red Green
Thanks for your reply.
I am a litle bit confused now.
I need to perform some other calculations at the same time and thats why I was thinking that I had to use interrupts. I can not use the pause command ... so I believe the first program is better.
Is this correct?
The RTCC input is made to count pulses, it's the way to go.
Bean.
Red Green
Oh well, go ahead and use the original version...
Bean.
Red Green
