Bad Jump?
I'm possibly just overlooking the obvious, but while executing following code I get a "bad jump or return address: 0203"
message from SXSim. (ver 2.06.02)
org $200
rK_Tab jmp pc+w
retw 12,6,0,0,0,6
table is called with
call rK_Tab
is this a known phenomenon?
Thanks for any help,
jeroen
Post Edited By Moderator (Jon Williams (Parallax)) : 9/17/2005 8:28:38 PM GMT
org $200
rK_Tab jmp pc+w
retw 12,6,0,0,0,6
call rK_Tab
jeroen
CALL @rK_Tab
Jon Williams
Thing is, I'm staying in the same page. Nevertheless I tried it, to no avail. [noparse]:([/noparse]
It seems when I run the prog on the sx-key it runs quite normal, I just seem to get this in the sxsim.
regards, jeroen
I'll try to discribe this more exact, I have been tinkering with this phenomenon a bit more. It seems that if I <RUN> over the code in SXSim there is no complaint, but no effect either, that is, table values are not read. However if I <STEP> into to code spot, I get the error message, which -when ok'd- resets SXSim.
Anybody seen this before? Happy with any clues,
cheers, jeroen
Does it work if you put each RETW value on it's own line ?
RETW 12
RETW 6
RETW 0
RETW 0
RETW 0
RETW 6
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
That's great, must be some small glitch in sxsim??
is there a bug list for that?
Thanks bean!
thanks for sharing your experience with SXSim. I'll try to reproduce that problem, and will fix it in the next version of SXSim.
Greetings from Germany,
G
You're welcome! and greets from switzerland
Jeroen
