playing sound files with the BS2
Is it possible to use the BS2 in combination with my PC to
(1) play interactively selected sequence of short sound files and
(2) wirelessly transmit them to a hundred feet away?
I am new to BS2 and microcontrollers, and would appreciate
any help.
any help.
There are sound modules that can save short speech files that you can access with a Basic Stamp. I'm not sure about any specifics, but I have seen similar threads in this forum that do have that kind of information. Try a search. Or plug in Google "sound module" or something.
If you have some specific reason for using your PC, you should let us·know.
For the transmission, why not mount the Stamp with a sound playback module directly on the application?
Rafael
csavage@parallax.com
I have in mind transmission of short sound files to a listener with a radio some
short distance away. A Pbasic program and/or keyboard input, in conjuction with
sensors from BS2 would select these short sound files from a large library.
The sound modules seem possible, though the cost would be a concern since
I probably need a large number. But I will definitely look into them.
Thank you both for the quick response.
http://www.parallax.com/html_pages/products/audiovisual/sound.asp
