unknown lcd
Hello
I·have·a LCD that I cannot identify.··
It is a LCD that came from·an AT&T paradyne that·I disassembled (lots of great parts inside).
it has a 14pin connecter plus the back light pins it has three·Hitachi·(it just has the symbol)·chips with HD44100H· and above it ·1M4 5· the display is (2X16?)
I don’t·know where to id this LCD·but it looks a lot·like the ones sold in the jamco catalog.
I·am a student with lots of homework so I·may not·respond quickly to any questions/responses.
Thanks.
Post Edited (Tinman) : 9/16/2005 7:31:02 PM GMT
Thanks.
·· Sounds a lot like a standard Hitachi-Compatible Parallel LCD...14 pin connector sounds right, but without a chip labeled HD44780 I am concerned it may not be standard.
csavage@parallax.com
Maybe this datasheet will help.
- Rick
I looked at·the diagrams but they were not much help because·I could not trace all of the wires·but are there any basic wiring diagrams for a·standerd parallel·LCD.·
ouwehand.net/~peter/lcd/lcd.shtml
Yes·I tried that and·I found somthing simalar but the pins of the chip are not what·I am looking for.
I·was wandering if there was a standerd pin configueration for the plug.
it is imposible to trace the wires because the CB is multy layer and the plug hides the rest of the wires.
the reson I dont use a volt meter to trace the wires is because on all of the lcd spects that·I looked at·said "never apply more than 5vdc and never mix up the connecton of the·pins" and the volt meter that·I have puts out 12vdc.
and so if I dont guess right the very first time, ZAP there goes my lcd!·
sucess is when you fail and try again
·-Churchill
Post Edited (crackticus pots) : 9/27/2005 3:14:08 PM GMT
