Half-bridge ?
Hello I was looking to drive a DC motor in forward only with a half-bridge mosfet setup and would like to know if I connect a 180vdc motor to the mosfets I have to somehow make the gate voltage on the·high side, low side or both mosfets·higher than the DC bus voltage? If so would anyone have a suggestion as how to do this?
·1+1=10
Do you have the spec sheets for the MOSFETS you're using? Generally you can Google them and then you'll have a place to start. As well, many manufacturers have application sheets on their web sites.
If you're only driving in one direction, couldn't you use only one MOSFET in the neg lead of the motor? That way, the gate voltage will be as low as possible.
