will serial port voltage ruin a BS-1?
·I just got my starter kit, with a BS-1IC and the SuperCarrier board. Like a dummy I hooked it up to the serial port on the pc without using the little serial-port adapter, and fired it up to see the "quick-start" output... The PC recognized that it was a BS1, but got no "echo" or other indication that the BS1 was alive.
·Would you guess that the serial-port voltage ruined the BS1·(a)for sure,·(b)maybe, or·(c)probably not? This makes a difference in·whether I·buy a new one right away & test by substitution, or try to find other reasons for non-communication.
·I looked at all the NV columns & indexed them for use as a reference. This is great stuff! Thanks for your time!·· -Eric
thanks for your time,· Eric
BTW, shouldn't see loopback when using the BS1, so don't worry about that.
Jon Williams
