Javelin with USB BOEBot — Parallax Forums
Randy HootmanRandy Hootman Posts: 9
edited 2005-09-13 07:15 in General Discussion
I have a USB BOEBot with a Javelin Stamjp installed. I am using the latest Javelin IDE on Windows XP and tryiing to download the HelloWorld program using the supplied USB cable. I get an error message saying the IDE can't find the Javelin Stamp. Any suggestions?
    edited 2005-09-11 16:50
    Randy,
    ·· Check to make sure your batteries are fresh.· The Javelin uses more current than a BASIC Stamp, and if it's not getting it, it won't respond.
    csavage@parallax.com
  • Randy HootmanRandy Hootman Posts: 9
    edited 2005-09-11 21:38
    Brand new batteries. When I plug the USB cable into the BOEBot, Windows XP gave me the message that it had found new hardware USB -> Serial and installed the drivers for it. The drivers were from the Parallax CDROM (I think). Hope this hellps. Has anyone else had success with the USB BOEBot and Javelin/Javelin IDE configuration?
    edited 2005-09-11 22:04
    Randy,
    ·· Is this a Desktop or Laptop computer?· Now that I know it's a USB BOE, try this...Go into your Control Panel and double-click the System Icon.· This should open your System Properties.· Go to the Hardware tab and select Device Manager.· Go down in the device list to Ports.· Click the + next to it to open it up.· Double-Click the entry for the USB Serial Port.· This should open the USB Serial Port Properties.· Click the Port Properties tab and select Advanced.· Under BM Options, change the Latency from 16 to 1.· Click Ok.· Click Ok again on the Port Properties window then close the device manager.· Try the programming again.· Oh, BTW, have you tried this with something other than a Javelin, for example, does the BS2 work on the system?
    edited 2005-09-12 07:16
    It's a laptop. Tried the settings for tor the device manager -> USB Serial you suggested and still nothing.
    edited 2005-09-12 14:41
    Randy,
    ·· You didn't mention if you have tried a BASIC Stamp on the BOE-Bot to see if it communicates or not.· Is the Javelin all you have?·
    edited 2005-09-12 19:51
    Put in a BASIC stamp and .... NOTHING. The BASIC IDE could not find the stamp either. So, I decided to quite being lazy and I pulled out my multimeter. Found no voltage going to the stamp. Checked batteries. They were good. Checked plug going into the BOE. Nothing. So something is wrong with the battery holder assembly.
    Next, I plugged in a fresh 9 volt battery. The BASIC IDE found the stamp. Put back in the Javelin and the Javelin IDE could not find the Javelin. Is the 9 volt too weak current wise for this to work? At any rate I need to tear apart the BOEBot and figure out what is wrong with the battery pack. This is a brand new kit just received from Parallax a few days ago.
    At any rate, this is fun trying to get this going.
    edited 2005-09-12 21:03
    Randy,
    If there's a problem with power supply then it lies with the battery pack. We've recently had a QA/QC with these and we're fixing it right now. Check the power supply at the solder tabs on the battery pack.
    I'll get a new one out to you ASAP.
    - Ken
    Ken,
    The power supply battery pack solder tabs are the culprit. Please send me a new one and THANKS!
    Randy
