Matrix Orbital LK202-25 Display Problem
I purchased the MK202-25 LCD display from Parallax, supposedly set up for use with the Basic Stamp. I am using the I2C bus from a BS2p. I have 4 other devices on the bus in addition to the display. The display is connected to 5V , SCL , SCA and GND on·the 4p·'Power Connector' to the left of the Keypad connector. The other 4 I2C devices work fine until I plug in the display. When powered the display comes up with the Matrix Orbital message but a scope shows the SCL line (pin 2) is being pulled permanently low by the display - hence the bus will then not work.
Is this a faulty display ? I note the backplane has shorting lands marked TTL and I2C etc·- it is the TTL pair that is bridged. Is that the problem ? There is no mention of these in the doc on the Parallax site.
·· I believe the TTL is in reference to TTL rather than RS-232 signals for the Serial I/O.· This should affect the I2C though. I will see what I can come up with though.
csavage@parallax.com
I belive that it can (from Matrix Orbital) have 3 different configurations, TTL (sold by parallax), RS232, and I2C, but I could be wrong.
·· I see, it's actually on page 12 of the document.
This is a professional project that I have to deliver in a week - 10 days. If the display can be replaced under warranty·I request cross shipping. The display was purchased from the web interface by our group secretary, Kathleen McKillen at NOAA in Boulder CO on 05 July 05 Order ID: 30860. I only put it into attempted service about a week ago after completing the prototype control board with the BS2p.
I'd appreciate your quick decision. Thanks.
Post Edited (Tom-Matrix Orbital) : 9/12/2005 7:16:08 PM GMT
·· Are you sure you're using the right connector on the display for the I2C connection?· Where are you connecting?
