Sound Circuits
I am helping a friend with a product he is working on that needs 2 seconds of sound.
He has brought me a device from a toy motorcycle. Tearing it apart it looks like this:
Back: http://www.stickerpub.com/boardback.jpg
Front: http://www.stickerpub.com/boardfront.jpg
This is what it sounds like (recorded 24bit 44k reduced to 8bit 8k) It actually sounds bettter at 8bit 8k than the 24bit 44k recording I made with my studio mic: http://www.stickerpub.com/motor8bit.wav
Waveform: http://www.stickerpub.com/motor8bit.jpg
As you can hear it plays a loop 3 times
What do you think is under the little black epoxy dot on that board? Is it a chip? Can you speculate what kind of chip it might be?
I am looking to play a motor sound with better quality
Could someone give me some options to duplicate this little player and perhaps a 2x or 10x quality improvement circuit as well?
Post Edited By Moderator (Jon Williams (Parallax)) : 9/9/2005 11:28:38 PM GMT
Jon Williams
Post Edited (Jon Williams (Parallax)) : 9/9/2005 11:29:35 PM GMT
csavage@parallax.com
Jon Williams
I would like to explore how this device works with the tools I have at my disposal. If I understand the timing and how it generates the pulses analog/digital in a laymans terms it would help.
Using the oscilloscope connecting the battery on one lead and one of the speaker wires I get the attached output.
Setting on the scope is 0.1 volts at 50 uS sweep
So am I correct that this chip is creating a pulse rate of 2,000 cycles per second?
I don't understand how to read the settings on the uS scale on a 20 Mhz scope I feel like an idiot
Scope Time/DIV
50
20
10
5
2
1
.5 = 10 Mhz?
.2 This must be 20 Mhz ? ( 20 Mhz scope highest setting, just a guess)
Jon Williams
Frequency = 1 / time; so, 1 / 50us = 20,000 Hz (20 kHz).·
But, obviously, there is more going on there than those spikes: it's a "complex waveform", a combination of frequencies.
