·· Yes and No.· Running it off a terminal program implies no program will be running.· You would also need to be able to calculate and send the binary values (highbyte and lowbyte) of the pulse width you're sending to the PSC, as well as the ramping speed and channel.· Usually this requires holding down ALT and typing in a 4-digit number on the keypad.· This may vary with the terminal program used.· Documentation can be found on the product page on our website.
·· As a side-note, to use the serial port of the laptop with the serial version of the PSC, you would need to connect it as shown in the attachment.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 9/9/2005 8:13:40 PM GMT
·· You can always write a program on the Stamp to receive commands from the HyperTerminal and control the PSC that way.· I have seen some posts on here regarding that before.· Then you can easily break it down into simple 1-letter commands with direct numeric entry of the value.· This could be done.
