Problem with the Sumobot...
Ok, we all know that this bot has two motors...but the right one doesn't seem to take any commands that I give it...CORRECTLY.
For example: you tell it to go forward, it goes backward...you tell it to turn, it does reverse, etc etc etc.
Basically, ALL this moter DOES is do reverse!
Anybody know how I could fix this motor? Please help..
By the way, if the problem is in the chip instead of the motor, how could you reset the chip?
Post Edited By Moderator (Chris Savage (Parallax)) : 9/8/2005 11:05:36 PM GMT
·· Have you centered the servos?· The Motor Alignment program is listed on Page 15.· This step ensures the Servos are properly centered.· If this step isn't completed properly, you could get the symptoms you're seeing.
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 9/8/2005 11:08:40 PM GMT
Jon Williams
Rien n'est plus proche du vrai que le faux
Albert Einstein
- La th
