My midi notes program needs help
I have this program which is supposed to read midi data notes from an eeprom data table:
[noparse][[/noparse] I/O Definitions ]
Prog_change PIN 14 ' Program changes
MidiOut PIN 15 ' midi output pin
NoteCtrl_5 PIN 5
[noparse][[/noparse] Constants ]
Baud CON 12
NoteOn CON $90
Noteoff CON $80
[noparse][[/noparse] Variables ]
result VAR Word ' raw pot reading
note VAR Byte ' note, 0 (C) to 11 (B)
soundVar VAR Word
noteOut VAR Byte
velocity VAR Byte
[noparse][[/noparse] Initialization ]
Reset:
velocity = 127 ' high volume
[noparse][[/noparse]EEPROM DATA ]
' D# F G G# A# C C#
D_sharpscale DATA 003,005,007,008,010,000,001
DATA 015,017,019,020,022,012,013
DATA 027,029,031,032,034,024,025
DATA 039,041,043,044,046,036,037
DATA 051,053,055,056,058,038,049
DATA 064,065,068,069,071,060,061
DATA 075,077,079,080,082,072,073
DATA 087,089,091,092,094,084,085
DATA 099,101,103,104,106,096,097
DATA 111,113,115,116,118,108,109
DATA 123,125,127,$FF,$FF,120,121
[noparse][[/noparse] Program ]
Main:
DO
GOSUB Get_keyofDsharp
GOSUB Soundbank_Change
GOSUB Notes_Off
READ (D_sharpscale + note), noteOut
IF (noteOut <= 127) THEN
SEROUT MidiOut, Baud, [noparse][[/noparse]NoteOn, noteOut, velocity]
ENDIF
LOOP
END
[noparse][[/noparse] Subroutines ]
Key of D Sharp
Get_keyofDsharp:
HIGH NoteCtrl_5
PAUSE 1
RCTIME NoteCtrl_5, 1, result ' read pot on 5
note = result / 53 ' convert to 0..11
RETURN
[noparse][[/noparse] Notes Off ]
Notes_Off:
IF (IN6 = 0) THEN
SEROUT MidiOut, Baud, [noparse][[/noparse]$B0, $78, $00]
ENDIF
RETURN
[noparse][[/noparse] Sound Bank Change ]
Soundbank_Change:
HIGH 14
PAUSE 1
RCTIME 14, 1, soundVar
soundVar = soundVar/4
SEROUT MidiOut, Baud, [noparse][[/noparse]$C0, soundVar]
RETURN
My problems seems to be at : READ (D_sharpscale + note), noteOut
For some reason the program doesn't seem to be reading the eeprom data table. I could strip away the D_sharpscale part and still get the same sounds.
Just wondering if someone with more experience might be able to see the problem.
Thank you for any help.
Tony
Post Edited (TonyA) : 9/8/2005 8:11:05 PM GMT
NoteCtrl_5 PIN 5
Baud CON 12
NoteOn CON $90
Noteoff CON $80
soundVar VAR Word
noteOut VAR Byte
velocity VAR Byte
Reset:
' D# F G G# A# C C#
Main:
DO
GOSUB Notes_Off
ENDIF
LOOP
END
Key of D Sharp
Get_keyofDsharp:
HIGH NoteCtrl_5
PAUSE 1
RETURN
Notes_Off:
IF (IN6 = 0) THEN
ENDIF
RETURN
Soundbank_Change:
HIGH 14
PAUSE 1
RETURN
Tony
You should really consider learning to use DEBUG so that you can test your program logic before attempting to send notes to a MIDI instrument.
Jon Williams
Post Edited (Jon Williams (Parallax)) : 9/9/2005 1:35:11 AM GMT
Sorry, I thought maybe someone could help me see where I went wrong. This program has not been posted in previous thrreads however. There were posts similar to this.
I've got if figured out now though. Thanks,
Tony
Jon Williams
There were numerous other code that were very similar, so no need for apology. I should go back and look at your previous help with my questions though.
I just threw that up in case someone else could add to what I was doing.
Thanks again for all your great help.
Tony
