Ping))) Sensitivity
Does anyone happen to know how sensitive the Ping))) sonic ranger is?· By sensitive, I mean will it be able to detect a 3cm diameter broom handle at 2.4m like the srf04 can?
The reason I am asking this is because I am about to start a project where I need to know the distance to objects ranging from a broom stick to a wall at distances of between 1m to 3m.
Harrison
Harrison
·· That information can be found in the documentation for the device at the following web page.· As a side-note, broom handles are pretty easy to detect within the range of such a device because of the·shape, which helps·reflect the signal back.
http://www.parallax.com/detail.asp?product_id=28015
csavage@parallax.com
So it sounds like the Ping is well suited for what I want to do.
Thanks for the help,
Harrison
Jon Williams
