QT113-D Touch Sensor Help
Has anyone tried the QT113-D Touch Sensor sold by Parallax. I have been playing around with it and I can not gain any or much sensitivity. Using the max size cap, .01 and a touch field about the size of a quarter, I can only trip it by touching it using a 1/16" of Glass. Any more distance and I can not seem to get it to work.I have also wired the Gain (Pin 5 ) to +5vdc. Any Help would be appreciated.
Thank You
Guido
Thank You
Guido
·· Have you followed some of the guidelines in the Datasheet for increasing the sensitivity?· Also note that some materials work better than others.· Glass is typically an insulator (And an extremely good one) so it won't work as well as some other materials.· The datasheet recommends using a bigger electrode, or reducing panel thickness or altering composition for some improvements.
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 9/7/2005 2:46:02 PM GMT
·1+1=10
Post Edited (Paul Baker) : 9/7/2005 3:50:26 PM GMT
