Basic Stamp and NJQRP DDS Daughtercard
I would appreciate any information anyone has on this subject. The DDS daughter card uses a 40bit programming word, represented by the formula: dphase = (fout * 2^32)/100^6. For 7040000hz dphase resolves to $001205BC01. Not a problem in VB6, but how to procede in PBasic with the 65535 limitation has me a bit perplexed. I fear I am mathematically challenged here
Jim, W4ATK
Jim, W4ATK
Like in their example:
shiftout 7,8,0,[noparse][[/noparse]$02,$BC,$05,$12,$00]
In fact I would suggest reading this page: http://www.njqrp.org/quickielab/index.html
Ryan
Ryan Clarke
rclarke@parallax.com
Post Edited (Ryan Clarke (Parallax)) : 9/7/2005 2:18:32 PM GMT
I think I have an approach, since I can use the VB to get "digit weights", i can store tables using DATA, access the tables with the symbol + digit and then build an add that accomodates carrys to build the 40bit stream a word at a time and use the SHIFTOUT as you suggest. I had lost sight of how valuable tables can be in a small controller.
Jim Rogers
Jim Rogers, W4ATK
j.t.rogers@charter.net
w4atk@charter.net
w4atk@arrl.net
groups.yahoo.com/group/basicstamps/message/44347
groups.yahoo.com/group/basicstamps/message/35802
groups.yahoo.com/group/basicstamps/message/35256
Tracy Allen
www.emesystems.com
Jim Rogers
Jim Rogers, W4ATK
w4atk@charter.net
w4atk@arrl.net
Jim Rogers, W4ATK
Jim Rogers, W4ATK
w4atk@charter.net
w4atk@arrl.net
I'm pleased that worked out! Can you post the algorithm you ended up with, that works? It might be good to have it here for reference.
I'm not clear on where your desired frequency input is coming from. In earlier stuff referenced above from Yahoo groups, the desired frequency was being entered on thumbwheels, read by the Stamp and converted to a control word for the AD9850. The thumbwheel problem was easy with 5 wheels and 10khz steps, but gets into a higher precision algorithm if you need to interpolate to the 0.03 Hertz precision (up to 65 mhz) the AD9850 is capable of.
Tracy Allen
www.emesystems.com
