Program
Is it possible to program the BS2sx to do a certain task ? What I mean is, when you ask the stamp a math question, it gives you an answer, because its program to know math, so I want to know·if I could program the stamp to know something, the way it knows math, and be able to execute the commands·I give it, like the stamp dose when you ask it a math question ?
Thanks !
Thanks !
Jon Williams
The stamp has a basic set of 'abilities', and you evolve more complex 'abilities' by clever ways of using the already existing 'abilities'.
Here is a really basic example (no pun intended):
The stamp can do addition. The stamp can loop. If you combine these abilities you can make the stamp count by 2's, 3's, or even 5's.
Ryan
Ryan Clarke
rclarke@parallax.com
