interfacing to a microphone
Hello
What is an ideal way to interface to a electret mirophone to a BS2PE, I believe I would need some sort of pre amp circuit, but how do I read in the voltage values, what command to use? RCTIME?
I am only interested in the voltage value from the mic, i.e. convert the ambient sound to a voltage range of 0-3V, I dont intent to do any audio processing/playback.
Thanks for your help
Jay
Jay
Jon Williams
Jon Williams
Do you just want to trigger the stamp when things get above a certain threshold?· or do you want to actively measure ambient sound?
In either case, know what your mic outputs is needed.·
Then you might need a small op-amp to bring things up to level and then it really depends what your actually use of the signal represents!
Steve
I am interested in the ambient noise continously, light up a bar led as the noise increases. All I am looking to do is convert the ambient sound to a voltage range of 0-3V.
Jay
Are you planning to use the stamp to light up these light bars? Or are you building a separate cct to do that....if you're building something, then you could easily 'condition' a voltage that it would work how you want (w/ RCtime?)....or, use some photodetectors mounted near each light bar and just monitor them....it'll show you stages, not a lot of resolution.
http://www.discovercircuits.com/V/vu-meter.htm has a few ccts for making a light bar cct.
I don't think you get much voltage out of electret mics....only a little more than line level signals (which is 1Vp-p)....So you'll need an op-amp for sure!
Steve
Nationl Semiconductor makes a number of bar-dot LED driver chips which will probably do exactly what you want, without even using a Stamp. Take a look at the following chips: LM3914, LM3915, LM3916. Here is a link to the LM3914:
http://www.national.com/pf/LM/LM3914.html
As I remember they show an example of an audio DB Meter, in one of the applications notes. Couldn't get much simpiler than that.
Bruce Bates
I posted the schematics for doing this in my post called "using piezo with BS2". It comes from a book by Gilliland. In this example you use a mic that is amplified by an opamp. This then goes into a schmitt trigger. The schmitt trigger IC chip converts the voltage into a square wave that can then be read by the stamp using the pulsin command.
In my experience you have to amplify the hell out of the mic for some reason. I am about to try adding another opamp to the one in the schem. to see if I can get the signal I need.
It's strange, but Gillilands circuit doesn't really work. It can work with increased amplification though.
Let me know if you try this.
Tony
Post Edited (TonyA) : 9/6/2005 8:01:38 PM GMT
But , you are using an AD converter , the 555 is being the AD .
Amaral.
