SX28 or SX28L
I'm trying to determine the difference between the SX28 and SX28L as a DEVICE directive.· So far I have found:
SX28:
The SX/B online help just says it is a device type.
SX/Key Dev Manual (pg 49)
SX28L:
Al Williams "Exploring ..." book· says·the "L" is a later version but you can use either. (pg 20)
Any ideas?
John J. Couture
San Diego Miramar College
SX28:
SX28L:
Any ideas?
John J. Couture
There seem to be lots of variations of device directives. I don't think there is a really good reason for the existence of most of the variations. For what it's worth, here's part of the code that SASM uses for handling the SX28 device directive variations:
As you can see, all the variations are internally converted to the same constant, which means it generates the same fuse settings. In case you're wondering what "bug9026" is, I have no idea. I didn't write that comment, nor do I know who did. If I had to guess, I would assume that whoever originally wrote SASM didn't handle the case of the "L" variant of the SX28 device directive.
Thanks, PeterM
