Current and voltage measurement
What is the best way to measure both voltage and current with a stamp? What I am looking to do is monitor a RV battery. Are there any website’s that have info on setting this up?
Chris
Chris
Although the link below references a multiple battery setup in an electric vehicle, the basic principles remain the same. Here is the link:
http://genki.home.ionet.net/BattMon/BattMonArticle.html
Essentially you will be measuring the battery voltage directly through one ADC, and the battery load (current draw) will be measured through a shunt with another ADC. Add an RTC (real time clock) if you choose to, and you can then calculate ampere-hours of discharge, if that's of interest to you. That should permit you to determine the "battery life left" in a no re-charge, constant drain situation. Use an LCD rather than a bar graph as used in the example, and you can display: present voltage, present current draw, and estimated % remaining battery life either sequentially, or through the press of a button.
Bruce Bates
·· Thanks for the link.· At first glance I wasn't sure it was anything interesting.· But once I got into it, I found I couldn't stop reading.· A lot of hard work went into that project, as well as some thinking!
csavage@parallax.com
Chris
I have purchased several 50amp shunts at All Elec Corp for < $15.00. They carry shunts from 25 through 600 amp. Site located at:
http://www.allelectronics.com/cgi-bin/category.cgi?category=385&type=store
Alternatively, the Alt Energy Store for solar power is also a very good source for shunts, boxes, cables, etc. Site located at:
Shunts: http://search.altenergystore.com/search?p=Q&ts=custom&w=Shunts&x=8&y=11
Circuit breakers & acc: http://shop.altenergystore.com/items~Cname~Fuses,Cables,Switches+&+Misc.+Electrical~Cc~ELECSAFE~Bc~.htm
Tony Thorne
tthorne@camano.net
tonyt@solarpowertracker.com
