Vibration Sensors or switches?
I am looking for vibration sensors, or switches that I can use the attach to guitar strings. When guitar string is plucked ---> activates the switch.
Can anyone offer references for a source?
Thank you,
Tony
Thank you,
Tony
·· You're in luck!· We have such as sensor located at the following web page.· If you have any questions on them, just ask.· I've used them myself and tested various properties of them.
http://www.parallax.com/detail.asp?product_id=605-00004
csavage@parallax.com
····· I would also be interested in ways to attach them to guitar strings and activate a switch. I would like to be able to use the string vibrations as triggers but didn't want anything actually touching the string, and killing the sound. If you have any suggestions it would be much appreciated. I think that this may be something I could actually accomplish with my level of understanding unlike some of my other ideas. Thanks for any help.
Al
Chris I.
·1+1=10
But certainly using a standard single coil guitar pickup will be the easiest.
There are some 'tuners', specifically for acoustic guitars, that will clamp to the head and when you pluck a string, it senses the vibration and indicates the note.· Neat little things!
Steve
·· While the vibra tab is capable of picking up slight vibrations from the strings without contact, that would put you in the position of not be able to easily detect which string is vibrating.· It would require considerable calibration to do that, but I guess it could be done.
Some guitars are configured for mutiple pickups, so you could remove a pickup and put your unit in the hole as a replacement. Positioning would be optimal.
If it is digital you want, I suppose and op-amp and an schmit trigger would be in the mix.
So, the trick to to wind your own coils on a soft iron core with appropriate insulation.
This is established technology since the 50s. Anything man-made can be made by any man. It is the invention of new things that is hard.
G. Herzog in Taiwan
Best Regards
Manuel C. Reinhard
