Help with RANDOM
I am trying to select values randomly, from data tables. How could I modify the following code to make this happen?
Suppose I have this data table:
' C D E F G A B
C_Scale DATA 001,002,004,005,007,009,011
DATA 012,014,016,017,019,021,023
DATA 024,026,028,029,031,033,035
DATA 036,038,040,041,043,045,047
DATA 048,050,052,053,055,057,059
DATA 060,062,064,065,067,069,071
DATA 072,074,076,077,079,081,083
DATA 084,086,088,089,091,093,095
DATA 096,098,100,101,103,105,107
DATA 108,110,112,113,115,117,119
DATA 120,122,124,125,127,$FF,$FF
And this:
Main:
DO
GOSUB Get_keyofC
GOSUB Get_keyofCoctave
READ (C_Scale + (octave * 12) + note), noteOut ' plays all notes in C scale with octaves.
IF (noteOut <= 127) THEN
SEROUT MidiOut, Baud, [noparse][[/noparse]NoteOn, noteOut, velocity]
ENDIF
LOOP
END
And this:
[noparse][[/noparse] Subroutine ]
Key of C Note Selection
Get_keyofC:
HIGH NoteCtrl_1
PAUSE 1
RCTIME NoteCtrl_1, 1, result
note = result / 53 ' convert to 0..11
Return
How could I read the above table chart values using the RANDOM command?
Thanks for any insight.
Tony A
Post Edited (TonyA) : 9/4/2005 10:31:29 PM GMT
' C D E F G A B
And this:
Main:
DO
GOSUB Get_keyofC
ENDIF
LOOP
END
And this:
Get_keyofC:
HIGH NoteCtrl_1
PAUSE 1
Return
Tony A
Main
· DO
··· RANDOM rndVal····················· ' tumble·random value
··LOOP UNTIL (Key = Pressed)·········· '·· until key is pressed
· theNote = rndVal // 128············· ' get randome note, 0 - 127
· READ·C_Scale + theNote, noteVal··· · ' read value from table
At this point you can do something with noteVal.
Jon Williams
Thank you. I was just wondering though. Since I have the data tables all written out could I do this too:
Get_keyofC: 'subroutine
HIGH NoteCtrl_1
PAUSE 1
RCTIME NoteCtrl_1, 1, result ' read key of C pin 1
RANDOM note ' make notes random
RETURN
result = note
RANDOM note
Since I only have a specified number of notes in the table named "C_Scale", would this randomly select notes in that table?
Main:
DO
GOSUB Get_keyofC
PAUSE rhythm
ENDIF
LOOP
END
Post Edited (TonyA) : 9/4/2005 11:27:43 PM GMT
rndVal··· VAR··· Word
idx·······VAR··· Nib
Main:
· DEBUG CLS
· FOR idx = 1 TO 5
····RANDOM rndVal
··· DEBUG DEC rndVal, CR
· NEXT
· END
Note that every time you run the program you get the same list of numbers -- this is the nature of psuedo-random number generators; they're mathmatically based, and not truly random.· By adding some external event you can get true randomness.
Jon Williams
Thanks. Very interesting.
What if the external event was the act of pushing a button? Would it become more random? (Since when you press a button, you will never be able to press it in a uniform way).
I understand what you're saying about the math, it would be inherently patterned. I also have to read more about "modulus".
Thanks again,
Tony
Modulus is simple: It returns the remainder of a division. The KEY is that // will always return a value between 0 and N-1, where N is the divisor used.
Jon Williams
