Is there a way to expand servo turning range for an RC transmitter?
Is thera a way to make the turning range for a servo the full 180 degrees over a RC set that normally turns the servo 90 degs?I still can't control my Hitec servo over the BS2p, was just wondering if I could use the stamp to manipulate the rc reciever for servo control?
Rafael
Rafael
Rafael
It's Only A Stupid Question If You Have Not Googled It First!!
Rafael
Thanks for the trouble, though.
Rafael
Rafael
Obviously, if the servo shaft has a big gear and the output shaft has a small gear - you get an increase in travel.
You might even get two or three revolutions.
It is a great question. Most people are thinking about using the gears to increase power or adjust speed.
But in this application, you can create new options for walking designs. Thanks.
G. Herzog in Taiwan
