Shiftin from a 74HC165
I am fairly new to the Basic Stamp world. I have spent most of yesterday and today tring to find out how I can convert the bit pattern from the shiftin, into seperate variables. I am tring to use the additional inputs as discrete switch inputs to increase seperate counters, ie; if input 5 goes high the counter for input 5 increases by 1. Can anyone point me in the right direction ?
·· You can use some simple math to do this.· All you need to do is add the bit position to the current variable.· For example if counter5 needs to be incremented when bit 5 is 1, then each read of the 74HC165 you simple do something like:
You would have to do this for each bit you wanted added to a variable.
csavage@parallax.com
Would this need to be in a Loop function containing the Shiftin command ? I am assuming that in your example hc165 would be the variable in the Shiftin function ??
·· Sorry if I seemed a little vague...I didn't have a demo together for this, just kinda top o' the head stuff...
