SX-Key not found on COM1 with SX-Key v3.10
Hi All,
I am using SX-Key v3.10 and when I try to Program my SX52BD I get a message "SX-Key not found on COM1".
I have a SX-DEV kit from SVTEHS and I can program my SX52 when I use the SX-TIPS software.
It seems to be a software problem...
If someone could tell me what is wrong, it would be great.
Thank you,
Patrick
Thank you,
Patrick
Jon Williams
I don't know if there is more option in the SX-Key v3.10 software ?
Patrick
Greetings from Germany,
G
i still get random "cant find sx key" ..... is there any way to adjust timing ?
and yes, i am connected to the right com port, have tried another computer, power is on, used usb/serial, and all that, even have a 1000 uF cap accross vdd and vss ( thanks gunther ) still get that error, and it makes it so i have to use sx-sim if i want to debug
·· Is the computer a laptop?· Also, did I see you mention you're using USB/Serial adapter?· If so, what brand?
csavage@parallax.com
So, if this error constantly shows up, there must be something wrong, and it can't be a timing issue. There are many possible reasons. Some of them are:
Wrong COM port, bad serial cable, bad or worn-out connectors, SX-Key pluged on to the ISP pin header in wrong orientation (it will not be powered in this case - but furtunately not damaged, according to my experience), no supply voltage, or voltage out of range (must be close to 5V) up - to the worst case - the SX-Key is defective. I don't think that this is the case with Patrick's SX-Key as he reported that it works with the other software he is using.
BTW: Here is a trick how to test if the connections between the COM port and the SX-Key are functional: Start up Hyperterminal, or any other terminal program, select some baud rate and format (does not really matter which one), de-select any handshaking options, and turn off any "auto-echo" option, i.e. the terminal program shall not echo the characters you type. Then type in some characters, and you should see them echoed back to the receive window (when each character comes up twice, you did not turn off auto-echo). The SX-Key's COM interface is designed and "hard wired" in a way that it echoes back each character received, no matter if it is powered or not. So, if you see the echoed characters, you can be sure that the hadrware connection between the COM port and the SX-Key is operational, i.e. the plugs and the cable are OK - at least.
G
I off power, on back again same problem. I pull out the SX Key Rev E. plug in again, same problem.
I have to repeat the above about 20 times before I get lucky.
I change to SXKey Rev F. and it just works, almost everytime.
Same board, same chip, same power supply, same serial cable, same PC, same software.
However, certain boards with certain SX chip works ok.
Everytime I complain about this on the forum, they tell me the same old story
1. Check power supply, make sure it's solid
2. They don't see a problem with SXKey Rev E.....
I think one problem is that the SX-Key draws alot of current when it first "wakes-up".
Try putting a cap very close to the Vss and Vdd pins where the key plugs in.
I have a 10uF cap relatively close and a 0.01uF cap as close as possible to the pins on my video overlay board and I never have a problem, although I do sometimes with the SX-
Tech board.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
Available soon!! Video overlay(OSD) module...
"I'm a man, but I can change, if I have to, I guess"
Red Green
But I am also sure that there are significant differences between SX Key Rev. E and SKKey Rev. F which nobody will admit to.
About current consumption, sometimes when I plug in any SXkey with power already on, it can go into a latchup mode, taking 3 times more current than usual.
I can see the LED on the power rail go dimmed when that happens. ( 7 percent of the time )
In this mode, it cannot program anything. I have to quickly cut the power, wait a while and then power on again.
But overall, the SXKey is well designed and robust b'cos it never dies no matter how you abuse it.
