Can I use BS2P with 20x4 or Larger Dotmatrix LCD
I'm wondering is it possible to drive a large LCD Panel with BS2P.
Resently I'm using it with 16x2 LCD and it is very easy to use LCDOUT command.
If I want to use a larger LCD can I use the same command ?
And are there any good links explain this application.
Thank you.
Thank you.
The big difference is between Character based [noparse][[/noparse]ascii] display input and purely graphic [noparse][[/noparse]dots in 8 bit groups] display.
The graphic display requires a lot more support as many of them use the same chip as the original dot matrix printer. So you have to create your own alphabet and number in EEPROM, find a way to assign an ASCII value, and call up sub-routines for each letter.
In sum, graphic displays require more low-level knowledge.
By the way, many displays have 'hidden' memory that can be paged or scrolled to. This means you can make the software step through a series of pages. In many cases, this allows you to use a smaller size to do the same thing.
After all, if you have 4 pages, the little LCD is really able to provide as much as one 4 times larger without pages.
G. Herzog in Taiwan
Some examples with Matrix Orbital displays with BS2 units can be found at http://www.matrixorbital.ca/appnotes/basic_stamp/
You can check out different displays at www.matrixorbital.com
