Capacitor Voltage question
I have a bunch of capacitors on hand that have voltages ranging from 6.3 to over 100 volts.
Everything I do is 5V so I have been using the lowest one I have available, but what's the difference?
Is it any worse to use a 16V 1uF capacitor than a 10V 1uF capacitor in a 5V circuit?
I wonder if this wire is hot...
If you are building production circuits, you will want to keep the voltage overrating within reason to keep costs down.
Nate
It seem standard in the electronics industry to always use a capacitor with at least twice the voltage rating that it will see.
For instance I would NOT use a 6.3Volt capacitor in a 5Volt circuit.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"One experiment is worth a thousand theories"
csavage@parallax.com
Doesn't a 10uf Tantalum equal a 1uf Ceramic in a filtering situation due to internal resistance? {I think I read that in a voltage regulator document}
I got an adjustible voltage regulator kit that uses a 25volt filter capacitor on the 18 volts pulsating DC coming from the rectifier bridge.
I got to thinking about this and I fear it just might explode under stress.
I picked up a 50V with twice the microfarads, but have yet to swap it out.
One has to be careful of how you count Volts. Pure DC without pulse is always simple. Volts are Volts. But.....
Volt-RMS [noparse][[/noparse]root mean square] is an average used in AC, not the peak. For AC converted to DC, you might have 18volts DC RMS coming out of a rectifier, but that is 70.7% of the PEAK voltage. The capacitor sees the Peak Voltage as a destructive force. So 18/.71 = 25.35volts peak. So, I have no safety margin and the situation gets even worse in the house current is higher than standard.
120 VAC/.71= 169 Peak Volts !!! in house current
This is a good example of where it is a problem.
G. Herzog in Taiwan
The RMS value is the amplitude of a sinusoidal ac current to deliver the same power as a particular dc current.
Or stated another way....the equivalent DC value of a sinusoidal current or voltage is 1/(sqr-rt 2) or 0.707 of its maximum value.
Ken
