Truck Leveler System
This is my first practical application for the Basic Stamp 2.· I was tried of guessing when my truck was level whenever I put a load in the back. Since I had 4 Ping units I decided to design a truck leveling system so I wouldn't have to guess anymore.· While it might not be as cool as other projects posted I am proud of it and wanted to share it with others.
Actually it is quitea cool project. I am curious to know how you plan to protect the PING units... Won't they get covered with road grunge and, once clogged, stop working?
Vern
·"We Are Not Human Beings Having·A Spiritual Experience,
··············... We Are··Spiritual Beings Having·A·Human Experience"
A very old trick with making sure your truck isn't overloaded is to buy a load of sand at some cooperative place with scales and check when you get to the right limt [noparse][[/noparse]e.g., 1/2 ton; 1 ton; etc.] Then take a tape measurer and measure the four corners to the ground while parked on a level surface.
After averaging the distance, you can weld four lengths of chain [noparse][[/noparse] one at each corner]. When driving the chain is secured up and away. Whenever you are worried about get busted for an overload, just drop the chains and check.
The same chains will provide you with a pretty good level load. Don't forget to include your own body weight in the gross weight as some cops won't let you get out.
Oliver
what type of schematic drawing progam is that ?
Thats cool.
japer
I use Visio Pro. I created a special electronics library, added the standard symbols that come with the program, and make my own for the missing electronics.
thanks for responding. i found i had a drawing program on my computer.
and found loads of symbols on the web.
that made a very cool schematic drawing tool.
japer
