Hypertrminal shows strange chars
I am trying to take data in from a BS2pe into Hyperterminal.·· I have read lots about this is previous posts especially that two caps are required between the pc DTR line and the Stamp ATN pin.· I have put these in place and Hyperterm no longer puts the 2pe in to the reset state.
The incoming data from the 2pe is fine but the outgoing typed data·is echoed and displayed by Hyperterm·as different characters.· The 2pe "sees" what is typed not what Hyperterm shows!
It is not a major problem but does seem a bit strange.
Does anyone know why Hyperterm does this and how to cure it?
Cheers
Helen
Cheers
Helen
You can avoid the problem by using a pin port other than 16 (used by DEBUG also), as that's the pin port where the automatic echo can and will take place. There is no way to turn it off, as it's a hardwired part of the circuitry of pin port 16.
Bruce Bates
As I said it is not really a problem but I just wondered why Hyperterm does this and the Stamp Debug terminal doesn't.
Cheers,
Helen
Jon Williams
