FAQ : How to handle [IF Temp < 0 THEN Loop] when Temp = -5
This post refers to an FAQ "Does the BASIC Stamp handle signed numbers and arithmetic?"
My Question : How to handle
··········· IF Temp < 0 THEN Loop
·When Temp = -5· & the expression should evaluate TRUE ?
The full FAQ is copied below :
Yes. The BASIC Stamp uses twos-compliment notation for signed numbers. This means that the expression: 0 -
10 + 5 will result in -5 if viewed as a signed number, however, most instructions see the number as a positive value,
in this case 65531 (the twos-compliment value for -5). All mathematical operators, except division, will work
properly with signed numbers in the BASIC Stamp and signed numbers can be formatted for output properly using
the SDEC, SHEX and SBIN formatters within DEBUG and SEROUT statements on the BASIC Stamp II, IIe and
IIsx. Be careful how you use signed numbers elsewhere. For example, if the value -5 is stored in a variable called
Temp, and you use the following statement:
it will evaluate to false and will not branch to Loop because -5 is actually 65531 in twos-compliment form and thus
65531 is not less than 0.
· testVal = temp + 25
· IF (testVal < 25) THEN
··· ' do something
· ENDIF
Jon Williams
Thanks for your reply to my post.·
Richard
