temperature
hello
I·like measure the temperature on two place at the same time is this possible.
greetings erik scholts
However, the stamp runs fast enough that you could make two different measurements that are only fractions of a second apart!
Steve
·· What are you trying to measure?· You could use two LM34 temp sensors and a dual-channel ADC to get two readings (almost) at the same time.· Depends on the application, really.
csavage@parallax.com
Jon Williams
I mean white one stamp, so we like to connect two sensors on one stamp,the time between the two sensor isn't so important because we like to mearsure the temperature on oil tank from a elevator·and the air in that machineroom.
Now we do that with one sensor and only the tank. The time between the two sensors can be 2 seconds or a bit longer· because we measure the temperture with a modem from a workshop with the debug function and that give also a·little bit delay.
thanks for the time
Erik
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
