BS2 OEM In PCBExpress Format
Is anyone interested in this?
I've completed it, and the PCBExpress version looks almost the exact same as the BS2OEM, not precisly but close.
I need to print out the images and compare to a BS2OEM board, really closely, otherwise I'd post it here.
I havn't made any boards on PCBExpress that have been produced, yet. I've created maybe 5-10 other boards, just havn't had them made yet, so it'd be greatly appreciated if someone else who is interested in it, go through it and verify all the traces and connections.
Knight.
Knight.
I have made around 8 boards from ExpreccPCB and have no problem. I am currently
working on laying out the BSP240 for OEM.
Just a thought .... I am going to layout my OEM BSP240 on the board with the
DIP connectors, just incase I need to throw a standard one in there. Post your express files
and I will help you take a look at them.
Koy Ja !
My board is also with the Dip Connectors. I figure those who know what they are doing can remove the traces going to the Dip connector and directly connect to whatever they want it to be connected too. Those who don't, can simply leave those holes present and connect like normal. [noparse]:)[/noparse]
I intend on modifying this already made layout, to only have the portions that are needed for running, not for programming, So, something like 3 resisters, the crystal, pic, and EEPRom, maybe some more components, not sure, just speaking off the top of my head.
I will post links to the files within the day. Probably late tonight.
Knight.
Knight.
Post Edited (knightofoldcode) : 9/13/2005 10:39:10 PM GMT
Mikey
Koy Ja !
I am also very interested in your work on this. I'd start it up myself, but I figured since you're already doing it, no point in my duplicating it.
Knight.
Knight.
Knight.
