Master Slave ; Using 2 stamps
I wanted to use a 2p40 and a bs2 to talk to each other to increase the I/O. I wasn't sure what to look up for some example code and pin connection. I tried master slave, but didn't find what I was looking for. Please let me know. ·
·· Please see the Editor Help File section on the SEROUT command.· There is an example connection of two BASIC Stamps networked.· Remember, since you're using two different type Stamp Modules, the baud rate constants will be different.· I hope that helps you out.
csavage@parallax.com
