Parallax RFs distance.
I need to send data using the 433.92 MHz Transmitter and
the receiver Items: 27986 and 27987.
I need to know the real distance of transmittion
because.
And the same question for:
item SureLink 900 MHz RF Module (item 30065)
Many Thanks,
because.
Many Thanks,
·· The specs for the transmitter can be found at the following web page:
http://www.parallax.com/detail.asp?product_id=27996
·· The specs for the receiver can be found here:
http://www.parallax.com/detail.asp?product_id=27995
·· The specs for the surelink are available here:
http://www.parallax.com/detail.asp?product_id=30065
csavage@parallax.com
The problem is that
PDF says 250 feet but realy is less than this.
Usually 50%.
I think that Parallax could test before selling.
Joe
Any of these variables,as well as many others, need to be considered. Even the type and frequency of data update can impact data integrity. For example FRS radios with a stated range of two miles means: two miles across water, probably ; two miles across a flat field, maybe; two miles across uneven terrain that is densely wooded, good luck. Your best bet would be to solicit·input from folks with a similar application.·Just remember RF has limitations and understanding those limitations can only help.
·· Definately consider Philip's response, as well as other types of interference, such EMI and stray RF noise in a given area.· Especially when between to relay towers.· The stated specifications are from the manufacturer and in some cases have been tested.· Of course, everyone's mileage varies.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
