Hot regulators
Hello!
My 5V 7805 regulator is getting very hot even though it's just powering the Stamp (that works). It's regulating from a large (7 Ah) 12V SLA. My 6V regulator for servos does the same thing, but they have a high current draw, so that may be explained.
does anyone know if this is normal for large batteries or if something is wrong?
Rafael
Rafael
·· The simplest way to explain the heat is this...The higher the voltage going into the regulator, the more heat the regulator will expend regulating the voltage down to 5V.· Current draw affects it as well on an almost equal curve, but again, the 12V input will definately make a 7805 warm (toasty).· A heatsink (Even a clip-on) will usually keep it within check until you start drawing excessive current.
csavage@parallax.com
·1+1=10
For the 6V regulator, the servos under load may be drawing several amps of current for a few seconds at a time, so I don't think double regulators would do the trick. The regulator is the tin-can bolt-down 7806 type. Can this handle the current?
Rafael
·· I agree with your assessment on the loss in the regulator, however I respectfully disagree on daisy chaining two regulators to reduce heat.· For one you're adding more loss to the system.· In all honesty I don't remember back that far, but I was once given what seemed like a really good explanation on why not to do this by a fellow engineer at the time (Who was way smarter than I).· But to that end I have never seen a schematic employing such a scheme, probably for the reason lost to my decaying memory...·
Rafael
Rafeal, Im in my lunch break now, Ill hop onto digikey and see whats availible in switching regulators.
·1+1=10
·· I would rather have had a leg to stand on when posting this, and I asked another engineer just now about it, and he also thinks that is a design no-no, but doesn't recall why either.· I will find the information, but I wanted to save any possible problems related to the design.
[noparse][[/noparse]EDIT] - Okay, it was as I suspected, the original issues I was warned about were related to transients causing oscillations/feedback problems.· Usable design requirements would include using the right capacitors such that the ESR (series resistance) prevents this.· That would require the person designing/building such a system to understand these concepts.· Myself I avoid it, but if it's to be suggested, then I would recommend a complete solution rather than concept, just because of design specifics.·
Post Edited (Chris Savage (Parallax)) : 8/26/2005 4:45:16 PM GMT
Sid Weaver
Do you have a Stamp Tester yet?
LM2574·5V, 500mA $1.86
LM2575 5V, 1A $2.79
LM2576 5V, 3A $2.80
Similarly there is the LM series 259(4,5,6) whichave current limiting and thermal protection, they are a couple dollars more.
these are just a few, to look at the entire selection, goto www.digikey.com search "switching regulator", click 5V in voltage dialog, click apply filter, then click "View Page". Look for the ones that say step down either in the description or in the features.
·1+1=10
·· Thanks for the information...I wasn't aware there was a 3A Switcher in that small of a package.· I wonder if there is a TO-220/5 package available in something similar?· I seem to recall Dr. Tracy Allen posting once about a TO-220 switcher...Although as I said, memory is failing these days and I could be wrong.
About the only way I can think of to run two regulators together is in a Cascaded style or to make use of a 78xx and a 79xx regulator.
I wouldn't trust the Cascaded method outside of the 5V supply reference to ground, because the input voltage (12V) can effect the
other outputs (6V and 11V).· If you are looking for a "ball park" voltage reference this would be ok I guess.
Using the not so popular 79xx regulator with a 78xx regulator would provide a more stable output voltage, however your GND reference
is lost and must "float".· Other circuits that reference GND MUST use the second GND (GND2).
Beau Schwabe
IC Layout Engineer
5V, 3A, TO-220/5
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=344294&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=344446&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=344601&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=345079&Site=US
5V, 3A, TO-220/7
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=344490&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=344662&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=345059&Site=US
http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=181260&Row=345107&Site=US
cheapest of the lot is the 4th and 5th link of the TO-220/5 for $2.80 and $2.04 respectively, the rest are > $4.
gotta love digikey's parametric searching, makes limiting down >2k possible regulators to choose from down to a managable number.
·1+1=10
Post Edited (Paul Baker) : 8/26/2005 6:15:41 PM GMT
focus.ti.com/docs/prod/folders/print/pt78ht205.html
The pt78ht105 is a 1.5 amp switcher
Bob N9LVU
·· A fountain of information!·
