RAM IC for SX28
Hi all,
I'm looking for a serial ram device that can store 32k bytes that I can write to from an SX28 at ~600kbps.· I'd like to read/write one byte at a time.· Besides the basic specs, ease of use is probably the next most important feature I need.· I have zero experience using memory although I understand most of the basic concepts.
Parallel memory chips with 20+ pins·are out of the question as I just don't have the pins, obviously.
Thanks.
Keith
Thanks.
Keith
FRAM is functionally equivalent to SRAM, but it is non-volatile and has near unlimited number of write cycles (measured in many years when a block is perpetually written to, it think·accessing it·at a rate you are looking to do,·the chip will last about 15-20 years).
·1+1=10
Post Edited (Paul Baker) : 8/24/2005 2:20:44 PM GMT
I started to make a request at MAXIM's site, but they wanted a lot of occupational information and a business address.
Does the industry frow on hobbyist scrounging for parts via their samples or is this something that they accept as a 'good will' gesture on their part?
I am a bit old school and feel you don't really get anything for free.
G. Herzog in Taiwan
·1+1=10
As Paul stated, RAMTRON is your answer. My experience with the SPI type shows it's easy to use and plenty fast.
Cheers,
Peter (pjv)
I think I've narrowed down my choice to the FM25256, 256kbit, 15mhz (should be plenty fast), 4-5.5v. I selected it mainly on capacity and the fact that it runs on 5v.
Paul, where'd you get your samples? Ramtron direct? Newark?
I'm already having trouble locating a source, however:
Ramtron's distributors are:
All American: Indicates they have engineering samples, and Im waiting on a reply email to see if they are available
Future: Minimum order quantity is 100.
Newark: Closest one I could find was low voltage FM25L256, but a month+ leadtime
Digi-key, Mouser: Ramtron isn't listed as a manufacturer
Jameco: Although I can't readily tell, it appears they might sell Ramtron, so waiting on email....
Thanks.
Keith
·1+1=10
In reality, if you learn how to use a part, and tell a friend who uses it in a commercial application, that still accomplishes the purpose of the sample.
Dan
(Just received 16 samples of ramtron parts at work!)
Page 7, under Write Operation, the datasheet linked above says, "[noparse][[/noparse].....]Subsequent bytes are data and they are written sequentially. Addresses are incremented internally as long as the bus master continues to issue clocks."
As long as I don't raise CS to terminate the Write operation, can I simply stop sending a clock on SCK until I have more data to write, and then start the clock back up to continue writing where I left off?· I did read the errata concerning suspending SCK in the middle of the data byte --- but that won't apply to me.· I'm writing whole bytes, so I'd never suspend the clock in the middle of the write of a single byte.
My main concern is that the WREN plus the write op-code including the address is really a ton of data, relatively speaking, and I'd hate to have to resend that for each and every byte I needed to write just because they were separated in time.
Page 2, under the SCK pin Description, "Since the device is static, the clock frequency may be any value between 0 and 15 MHz and may be interrupted at any time."·seems to confirm what I'm guessing, but I really have no experience here.
And the related question is, if I can do this, what's HOLD for? [noparse]:)[/noparse]· I'm trying to make this as simple and straightforward implementation as possible using the fewest number of pins.· I'd be happy with the 3-pin minimum!
I think I'm going to be bit-banging here, not using the ISR for the clocks.
Thanks.
Keith
Perhaps you can devise a testbed to experiment what the chip will do under various situations.
·1+1=10
Just back from a week of R&R.
Indeed, things are arranged so you may be temporarily stall the clock/data (while hi or lo) to do something else, and then carry on where you left off, provided you did not raise CS. Every time CS is lowered, a new sequence is started, requiring issue of a command, address, etc.
The stalling technique works very well, as that is exactly what happens when I'm accessing the FRAM, and then the RTOS fires to do someting else, and on task suspension by the RTOS, things merrily continue as if no interruption had occurred.
As for HOLD, I have not used it, so no opinions.
Cheers,
Peter (pjv)
pjv, I suspected that might be the case based on how the datasheet read. In case you were wondering, I'm still working on my MFM floppy project. No real progress, but I'm trying to take the PC out of the equation by using RAM or a faster USB xfer.
