Can anyone share a simple pulsin schematic?
I am looking for a simple schematic for use with a pulsin program. I know there should be a resistor and a cap, and a line to the +5, but not sure exactly how to set this up. Should there be a 220 k ohm resistor before the input pin too?
My idea is to create a simple all notes off midi switch using the pulsin command like this:
Allnotes_off:
PULSIN 6, 1, pulse
IF pulse >=1 THEN
SEROUT MidiOut, Baud, [noparse][[/noparse]$B0, $7B, $00]
ENDIF
Or would this be better (using rctime)?
Allnotes_off:
HIGH 6
PAUSE 1
RCTIME 6, 1, pause_result
IF pause_result >=1 THEN
ENDIF
Thank you,
Tony
Post Edited (TonyA) : 8/24/2005 12:00:09 PM GMT
Allnotes_off:
PULSIN 6, 1, pulse
IF pulse >=1 THEN
ENDIF
Allnotes_off:
HIGH 6
PAUSE 1
ENDIF
Thank you,
Tony
Jon Williams
I did this:
Notes_Off:
IF IN6 =0 THEN
SEROUT MidiOut, Baud, [noparse][[/noparse]$B0, $7B, $00] ' send out on channel 0
ENDIF
DEBUG ? IN6
I get state readings from the pin (pin 6), but no effect on the notes, they don't turn off. Maybe because the channel for all notes off is different. I have to see.
Thank you,
Tony
Post Edited (TonyA) : 8/24/2005 1:13:57 PM GMT
Thanks.
