Controlling a RoboSapien with IR Buddy?
Hello -
I am working on a project that needs to control a RoboSapien, and I'm looking a possibly using Parallax's IR Buddy to send the RoboSapien it's command messages.
According to the RoboSapien info:
"The IR Carrier is 39.2kHz. Data is modulated using a space coded signal with 8 data bits (data clock is 1200Hz, but actual data rate varies depending on the data)."
An example command: "$80 - turn right (on left side of remote)"
If anyone can let me know if the IR Buddy will be capable of sending the right codes to the RoboSapien, that would be wonderful. I'd hate to order one and find out that it wouldn't work.
Thanks!
Tim White
Thanks!
Tim White
Please don't buy an IR-Buddy to talk to the Robosapien, it is not going to work.
