BS2P and PSC
What has to change in the program that comes with the PSC to work with the BS2P.· Is it that the baud constant is wrong?· What does it need to be set at?· thanks
It's Only A Stupid Question If You Have Not Googled It First!!
Post Edited (altitudeap) : 8/21/2005 7:31:38 PM GMT
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
·· Since the PSC uses "OPEN" baud mode, you should add $8000 to the 1021 for the BS2p, giving you a final baud value of 33789.· If your code adds the $8000 then use the 1021.· If you are implicitly specifying the baud rate then use 33789.·
csavage@parallax.com
