Servo controller hangs up
Why would the servo controller hang up this happen mostly on power up I am using a digital servo connected to a gyro and a BS2 stamp @ 2400 baud when I push the reset on the controller it will unlock is there a code to unlock the controller in program?. Hank van Buuren.
·· What is powering the servo controller?· How much voltage?· What is powering the servos?
csavage@parallax.com
Are all the grounds tied back together? Everything (servos, additional DC·power supplies, external boards, etc) all need to meet at a common ground point under most circumstances.
Could you give us a better idea what you mean by servo controller·"hang up"? Does it just not respond, or is there some other symptom?
Bruce Bates
·· If you're using a BOE with a jumper between the Servo Headers and it's set to Vdd, then you should be okay on voltage there.· If you don't have the jumper, you could have a problem.· If you're using a servo cable to connect to the PSC, then all 3 lines should be connected.· Likewise, if you separate power supply is connected to both terminal on the PSC, the grounds should be okay.· What makes you think it is locking up?· Do you have a standard servo to verify that it's not something with the digital ones?
