Does serial port networking software exist? — Parallax Forums
lunarknightlunarknight Posts: 13
edited 2005-08-21 02:38 in General Discussion
Hi, I just recently bought a notebook and it does not have a serial port. I spent a lot of money on the notebook and would like to save some money by not buying a usb to db9 cable unless I absolutely have to. I was wondering if there was software that could create a virtual serial com port on my notebook, and have data transfered/recieved via the internet or lan to my other pc with a serial port connected to my bs2.
Has anyone done this themselves? Any help/suggestions would be appreciated, thanks.
- Vincent
    edited 2005-08-21 00:42
    Vincent,
    ·· Even if this was possible, it sounds like it might be likely to cause problems with the timing of the data required to properly program the BASIC Stamp.· Think of it this way.· Current Serial Ports on laptops are sometimes prone to issues, as are some USB to Serial configurations.· In these cases you can usually turn off the Serial FIFO buffers, or on the USB turn down the Latency Timer.· What would you do on a virtual networked port?· I think it would be more issue than buying the USB to Serial adapter, which we have for $34.00.
    csavage@parallax.com
    edited 2005-08-21 01:51
    Do you just want to transfer data between your laptop and PC I'm confused?
    If so and you have a Parallel port on your laptop and PC, I would go with DCC (Direct Cable Connection)
    www.cellarstoneindia.com/cable_pdf/Parallel-Windows%2095_98%20%20to%20Windows%20XP.pdf
    ...This is going to be SLOW, but it should be faster than a serial connection. You will need
    a special cable for DCC you can either buy or make your own ( I prefer the latter)
    www.lammertbies.nl/comm/cable/parallel.html
    Beau Schwabe
    IC Layout Engineer
  • steve_bsteve_b Posts: 1,563
    You can buy PCMCIA cards with serial 'pigtails' that will give you a serial connection.
    I don't think these cards cost too much!! ~$50usd?
    Steve
