Using a USB Flash Drive with the Stamp?
Hi all,
I did a search in the forums and did not stumble across anyone mentioning this.· If I missed it, please feel free to smack me and point me to the thread.· :-)
I am thinking that for projects that require a lot of logging, it would be nice to write directly to a USB Flash Drive.· If you could write to a .txt format, then you could easily just unplug the Flash Drive and then go to a PC somewhere and download the file.· This would give you enormous amounts of memory space for logging files.· It might also allow for a great amount of r/w information since Flash Drives are cheep!
Any thoughts or ideas?· I saw there is a USB to stamp(TTL) interface, but know nothing beyond that.· Am I wasting my time trying to go down this path?
Thanks!
-Michael
Thanks!
-Michael
·· This topic comes up at least once a month.· However I did do a quick search and found the following threads dealing with this subject.· You may have to scroll up on some of these.
http://forums.parallax.com/showthread.php?p=515633
http://forums.parallax.com/showthread.php?p=519419
http://forums.parallax.com/showthread.php?p=524411
http://forums.parallax.com/showthread.php?p=525840
http://forums.parallax.com/showthread.php?p=546665
csavage@parallax.com
USB requires a 'master' and 'slave' device. Easy to build a 'slave' device with FTDI. 'Master' device requires a hard drive, to load the drivers to talk to each 'slave'. Thus a BS2 can't be a 'master' device. Thus a BS2 can't talk to 'slave' hard drives, mice, keyboards, other BS2 slaves, 'slave' USB to RS-232 converters.
Somebody IS trying to build a small 'master' device, but I don't think it exists quite yet.
There IS a small unit which will interface a BS2 with Flash Drives, I believe, but it's not USB based.
·· Allan got me!· I saw Flash Drive, but didn't notice the USB part...My post related to searches for Flash Drives, not USB drives.·
I did some sifting through the archives some more and skimmed the threads you sent.· Thank you.· It would appear that maybe the USBwiz from ghielectronics.com might do what I want.· I will have to read the manual more carefully, but it appears that I can interface my stamps to their chip and write files to a USB Flash Drive.
Thanks for the responses.· Now I just need to go read (luckily since it's·company business I can educate myself on company time!).·
· If you don't have to have the USB flash drive format, Rogue Robotics has a data storage module that uses SD cards.· You can find that module here: http://www.roguerobotics.com/index.php?module=pagemaster&PAGE_user_op=view_page&PAGE_id=5&MMN_position=6:2:5· Hope that helps.
Tim
Tim
EDIT - I should have mentioned in the original post that the uMP3 Player module is also SD card based, and can be used for data storage as well.· Just so it's clear there are two seperate products, the Data Storage module and the uMP3 Player module which can also be used for storage.· Both are SD card based.· Tim
Post Edited (Tim-M) : 8/19/2005 8:40:58 PM GMT
