is Stamp necessary in this case
Folks I need a component that will gate-enable three seperate gates in a cyclical repetitive order - Gate 1 the Gate 2 then Gate 3 - at seperate but equal intervals of 1 microsecond. After that is done, it restarts. Thats all I need. Is a PIC really necessary like a Stamp or can a less expensive discreet component work?
Actually no it is not necessary to use a processor for that. I really hate it when I say that. You can get that job done with a few dollars in parts. Just set up a 4 bit counter (only 2 are needed but they usually come in minimum 4 bits). Set it to reset after count 3. Hook the counter ouputs to a 2-4 bit encoder and use encoder outputs 0 through 2 as your gates 1 to 3. The counter just needs a 1MHZ clock source and it's a go.
I didn't specify parts because of bad memory and to tell you this. There is a great old book that is perfect for solving problems such as this. It's the "TTL Cookbook". You don't have to use TTL gates but the book is a must have for logic gate solutions. I bought a copy in tech school and it stays within arms length of my workbench 20 years later.
Lee Harker
Tbag
On the other hand, you might consider using an SX controller. For example, I needed to stretch two pulses (see the projects section of this forum: http://forums.parallax.com/showthread.php?p=541621. I could have done this with two NE555s, for example, with the additional passive components required around the 555. Using an SX28 with its built-in 4 MHz clock (not very stable and precise, but good enough for my need), the external parts count was zero.
So "tailoring" your own logic with a micro controller is an interesting alternative to discrete components, even price-wise.
Greetings from Germany,
G
I don't think there's any glaring logic errors in this design... and I suspect it's cheaper.
This site introduced me to counters and decoders after AI read the first post and made it very understandable - check it out!
http://www.kpsec.freeuk.com/counting.htm
-T.
you are right, having a micro controller, like the SX "on board" gives you a good chance using it for other purposes besides generating the pulse sequence you need. Actually, an SX would feel "bored" running just this task
Blease get me right on the "zero external components" approach. It can only be taken when the precision of timing is not that critical as the SX internal RC clock is not very stable. Changes in ambient temperature, supply voltage and other factors have an impact on it. For applications requiring a better timing, you will need to spend the extra pennies for a resonator. Nevertheless, this will still end up in a cost-effective solution.
Instead of soldering, you would have to do some programming. I assume that you are familiar with BASIC Stamps, so using the SX/B compiler for the SX should not be too difficult for you.
G
