are you asking about pin 1 on the stamp itself. the Sout pin. aka pin 16 in the compiler.
if yes, you can use Sout to transmit serial data. its already inverted though becuase it can generate rs232-esqe leveling (to talk to debug and hyperterminal and whatnot).
if no then
are you asking about open collector baud modes?
if yes, pullup pin 0
if no, neither, the signal will power itself, just make sure the receiver shares a ground with the stamp.
sometimes never is better than sometimes.
Post Edited (nick bernard) : 8/16/2005 8:08:02 PM GMT
If you use S_out to transmit serial data, you must also connect S_in. The BS2 uses the S_in voltage to 'modulate' S_out -- that's how it gets its MAX232-like voltages.
I'm using a breadboard, so I'm using a 9 volt battery to power my stamp, called a stamp stack, I was just wondering if I'm suppose to connect the + voltage to the outputting pin or the - voltage ?
if no then
Thanks !
I don't know what pin you are calling "the outputting pin". Typically you don't connect ANY voltage to an output, you connect an input to an output.
