Help with the PSC
does anyone have some sample code for using the PSC.· I have read the instructions that come with it but could use some example code that i could experiment with for standard (non-continuous) servos.· Thanks for the help guys and girls
There's no such thng as a stupid question.· I disagree.
It's Only A Stupid Question If You Have Not Googled It First!!
·· The examples for standard servos applies.· For contiuous rotation servos the servos will simply continue to rotate in a given direction.· But you use the same commands to send a different pulse-width to the controller for a given servo.
csavage@parallax.com
