High Torque Servo, where to buy online?
Hello everybody, im going to work on some stuff that requires high torque servos. I need some servos that could handle easily 30 - 90 kgs-cm.·Every help, advice is warmly welcome.
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
http://www.robotzone.com/customer/product.php?productid=186&cat=51&page=1
Here is a quote from that page:
There is also a 'standard' one not using the Hitec HS-805BB and HS-815BB servos at:
http://www.robotzone.com/customer/product.php?productid=185&cat=51&page=1
fwit: http://www.robotzone.com seems to be the only place I have seen this type of thing, but somebody smart with gears could have done something simular. It's just nice to see it all packaged and pretty like that. :-)
Post Edited (OakGraphics) : 8/15/2005 8:26:15 PM GMT
The above top servo - once converted to metric on it's highest ratio is 19.1415087 kilograms per centimeter.
I think you are headed to linear actuator land.
Tim
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
to answer your last Q, digital servos are usaly stronger, quicker, more accurate, and more expensive. the only difference is that digital servos "refresh" their postion something like 5-6x more than standar servos. but senting signals should be the same!
-MM
Post Edited By Moderator (Aristides Alvarez (Parallax)) : 8/19/2005 10:34:58 PM GMT
Best Regards
Manuel C. Reinhard
good luck,
MM
