There is no variable extender. Conservation is good -- make sure you're not using a Word when you could use a Byte, or using a Byte when you could use a Nib, etc. In 12 years of BASIC Stamp programming I have had exactly one application where I ran out of variables. Since the program had two distinct modes, I saved one set of variables in EEPROM (using WRITE, recovering with READ) while the other mode was in use.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Jon Williams Applications Engineer, Parallax
What i have done to extend my variable space is to recycle variables. What i mean is that when a variable doesnt need to be used again or will be written and has no use for some time, i use it for another purpose.
Jon Williams
Best Regards
Manuel C. Reinhard
